Yaffe or HHI neck kit for 26?
  • Yaffe
    Votes: 3 27.3%
  • HHI
    Votes: 8 72.7%
  • Total voters
    11
Nova606
Alrighty... Let me hear you opinions... I have a wild hair right now and thinking about doing something... Trying to figure out which route I want to go...:stupid:
both achieve the same desired effect (yaffe has some room for changes in stretch/up ), hhi is more money up front, but requires less fab, yaffe block kit is cheaper but requires more fab work....
Classic$98
If I am not mistaken you can play with the stretch with the yaffee block. The hhi has 2inches out and 2inches up built into the kit so no wiggle room there. If you don't like the extra stretch this may not be appealing. The hhi kit looks very easy to install but the extra fab in the yaffee kit isn't a big deal for a guy that works with metal. I would lean towards the block because of the stretch.
Sonic69
We've done both and the HHI kit was hours less of work. The Yaffe kit has you make sheet metal panels to cover it up. HHI kit is easy. Cut off neck. put new neck on and weld. Make sure either way everything is competely squared up.
