Topshop bags ( do it yourself exsaust )
topshopbags
931
mitchell,sd
We have bags that you can cut out your own exsaust DO IT YOURSELF EXSAUST, we have areo space foam sandwitched in betwwen our bags, the no exsaust style but we have customers that cut there own out.This is a how too! The inside is still all fiberglass so no water will get to the foam and you will not have to mess with the carpet.Here is what you need to do
First mark were your exsaust needs to be, than cut it out with a air saw, then when your hole shape is where you want it, then grind the foam down a 1/4'' below the fiberglass! On all the fiberglass edges make sure to taper the edges of the fiberglass so the short strand fiberglass filler can hold on the edges. Make sure to use everglass short strand or the other one in the picture. thats the only thing that will stick to our resin that we make our bags out of. The fiberglass filler will stick to the areo space foam the foam is designed for this. But if you do it yourself we dont warrenty the exsaust area because it is not done by our shop.
topshopbags
931
mitchell,sd
First mark were your exsaust needs to be, than cut it out with a air saw, then when your hole shape is where you want it, then grind the foam down a 1/4'' below the fiberglass! On all the fiberglass edges make sure to taper the edges of the fiberglass so the short strand fiberglass filler can hold on the edges. Make sure to use everglass short strand or the other one in the picture. thats the only thing that will stick to our resin that we make our bags out of. The fiberglass filler will stick to the areo space foam the foam is designed for this. But if you do it yourself we dont warrenty the exsaust area because it is not done by our shop]
here is the rest
