Pickard Trees or Tricky Air & Billet Trees for a 23 inch front wheel
rbfrat
28
Plymouth MA
I am planning to install a 23 inch front wheel on my 2006 Streetglide. I've talked to both companies and I'm leaning toward pickard's trees. I should note that I don't want to cut my neck. I have an S&S 124 in it now and I ride like a madman. I really want to be sure I'm going to be wobble free before I make the move and invest the money. Does anyone have any opinions or experience with these trees. I will not use Kewl metals trees since I don't like the look. Thanks
There a good choice. You could go with HD trike trees and a lowering kit and then you would have to buy the raked bezel and skirt
TNTCC
657
WV
Never ran the trike trees but I can tell you the Pickard trees work great.
rbfrat
28
Plymouth MA
Does anyone have any photos of a Sreetglide with Pickard trees and a 23 wheel with a Sinister or Yaffe glide fender??? Also any clearance issues with with a Yaffe stretched tank and the ignition switch?
BIG TIME BAGGER
824
If you use trick trees you won't have to buy the bezel. It's already corrected for you, might hit up suave maybe he'll cut u a deal on his
pickardbaggerparts
761
Richardson, TX
its our own neck stem and nut. You actually adjust the fall from the bottom tree, not the top. That way it's more serviceable and easier to get to with out tearing off the fairing
rbfrat
28
Plymouth MA
here ya go... our trees with a 1" lowering kit and our extended fork stops. No need for headlight bezel or trim kits or extended fork tubes...
Looks great. I am still using my my highway bars and plan on using a glide front fender. Any problems I should be aware of?? I already have a HD 1" lowering kit on my bike. Can I use it or do I have to remove it and use yours?
BIG TIME BAGGER
824
Trick trees allow the use of a crash bar and lower the front almost an inch so u could pull the lowering kit and sell to offset the cost
BOOGIE
5
I did the HD trike trees and had it up to 110 no woble
DCHBGR
569
Virginia Beach, VA
Have heard both good and bad about Tricky so I dunno...I do know that Pickard shit works and I am doing another right now...waiten on wheel and a rear fender!!!!
