PBR 300x4 Number 3!!!!!!!!!!
Mr.Goodtime
362
Pinson, Alabama, United States
Im running (2) 6.5 Polk audio components...(2) 6.5 polk audio with (2) 1 inch tweeters with Polk audio crossovers...I have the gain set at 7...and the ground is to the battery...Head unit is a Sony,,I cant think of the model number right now? Its the one with the tray.
On a side note, I had the amp in the fairing. Right behind duel 8000K HID lights!!!...I think the amp was getting too hot from the lights??? I mounted this one in the bag and i guess we will see how this goes!!!
Check the impedance on the polks. That amp only likes a 4ohm load. I know they recommend you set the gain at 5 with the hk head unit. Not sure about with a sony
TNTCC
657
WV
Rockford amp is only 4ohm stable so if your @2ohms thats where your heat is. I've been running the same amp at a 4ohm load for a year solid without any issues. Set my gains at aprox 6 and go.
Rozkopeeko
665
Ft. Luaderdale
yeah i heard that a lot ,, guys running the amp on the wrong ohm and causing it to self destruct .... RF have historically been powerful amps
Mr.Goodtime
362
Im 4 ohm all the way!.....Still eating them?????....If i set my gain at 5 like RF suggest, then I need half my money back!...If there telling me that their product will only hold up to half of what they say it will fuckin do!!!:19:
Rozkopeeko
665
Ft. Luaderdale
Yooooooooooooooooooo trried installing my rf amps ................... Freakin smoke !!!!!!!!!!!!!!!!!!!!!!! Not even paperweights .......... I am so freaknnn pissssed!!!!!!
Roz give me a call. 240-281-7287. I've had my problems with the rf amps but have worked them out. Rf will stand behind their products though. We will get it straight
Not sure if it will cause a heat issue, but I've always been told the ground should go to the chassis instead of the battery. There is a ground lug right in front of the battery just behind the rear tank mount.
MyRide7
Gauge & HK/RS radio LEDs
113
East Peoria, Illinois
Goodtime, I fixed this issue in my fairing by purchasing a 12v DC "computer fan" from Radio shack and wired it to come on/off with ign and zip tied it inside the fairing to blow across the amp. Its quiet and qith our 100+ temps this summer its still working.
Marty
MyRide7
Wish me luck!..Im mounting this one in my left saddle bag in the A.M...I believe my HID's were getting the other 2 too HOT!!...I guess we will see huh!!!!
