Tboner, how did you attach it under the seat to the fender? I see that the mounting plate isn't very long, I can't imagine that just that back seat bolt does a very good job for stability.
the way I remember it is there are 3 holes in the chrome backrest bracket(under the seat) then there is a matching plate with threaded studs that goes up under your fender, put it thru the 3 holes that need to be drilled and thread the nuts on then attach seat. It looks as if it was mod'd which is an easy task. Check ebay as they alway have them listed for a deuce. I dont think they are in the HD catalog anymore as the deuce was replaced with the rocker. I sold mine pretty cheap, around 60 bucks....(if U need a pic try a web search for a deuce backrest , when u see it it will make sense)
