My 2015 FLHXSE 26"
MiCrow
58
Figured I would share a picture of my project this past winter. I did the AS bolt on for 2 reasons, 1 so I could try a 26" to see if I liked it, 2 I'm nervous about cutting an SE
donald64bo
13
Looks Good.
Any Wobble issues? What is the highest speed you had it up to with the 26?
MiCrow
58
Admittedly, it does wobble a bit about 90-95. I will likely tighten it up a bit.
If you guys can’t get the issues solved please post and I’ll/we’ll try to help.
donald64bo
13
AS is sending out another “Bolt on†take.
They think there’s a chance it could be a slight defect. I’ll let you know if that works.
I’ve replaced the bearing in the rear, rear tire. Checked the wheels for being true, last but not least, tried different air pressure front and rear.
donald64bo
13
Installed the new AS neck but high speed wobble is still there?
Replaced rear bearings, new tire, adjust air pressure front/rear, what else are we missing ?
DanHappy
509
So the factory thinks the part is bad, so they are sending out another for you to install? Man, that's allot of work for a possible fix.
DanHappy
509
Looks good! How's she ride? Any air or anything on the front?
MiCrow
58
It's completely stock other than the bolt on rake, no airride. Actually, I talked with Mark at AS and tried a few things he suggested, but not all of them yet.
donald64bo
13
Same here, all stock suspension.
What are some of the things Mark suggested?
donald64bo
13
My 2015 FLHXSE 26"
Got the bike up to 120 today no issues.
Apparently I had two issues, rear shocks, and top frame to motor mount that was pulling my vertical alignment off. ( I hope that makes sense)
DanHappy
509
Doing 120 anywhere around my area and you will fit 50 potholes! Going 75 - 80 in my area is iffy. Lol
Good that you got it figured out.
