Lowering blocks question
shadow
542
arizona
Is anyone running them with the monroe set up? I have monroe set up and obviously not going to dump it while riding but thinking of when parking it now my rear fender is about 1 1/2" off the ground slammed i'd like to be able to set it almost touching when parked. For those of you running lowering block does it change the ride at all or feel the same as if they weren't there?
As long as you have the clearance they will ride fine. I bought a set for the Red Sled then realized I didn't have clearance above the tire to run them.
shadow
542
arizona
Bill when you say clearance was that when you had your shocks aired up for riding or aired out? I have alot of clearance now and suspect the blocks would make it real close or interfere only if i lost air from a leak while riding.My electrical is not an issue cause i have the wires off to the side under my fender running through a small tube tacked to to fender.
I mean clearance with the air dumped.
