Internal Front Signals
repsol69
5,072
Pt. St. Lucie, FL.
OK Got it installed..Whew!!! You have to grind down ( a lot ) of the back of the light to fit the Headlight bucket other than that its easy
Is that the Ebay headlight with LEDs in it.
Nomad
2,273
Cleveland, OH
How are the turn signals with this headlight? I'd really like to dump my light bar up front on the king...
Nomad
2,273
Cleveland, OH
How was the wiring to get the turn signals to work rep? Did you need a load equalizer or whatever they're called?
repsol69
5,072
Pt. St. Lucie, FL.
Yes..I had one from Custom Dynamics for my rears so they worked fine...i just cut the ends off the stock ones and attached them to the new turns so they were plug n play
leblanc1
151
Utah
Is that the "7" Crystal Headlight w/ White LED Angel Eye Halo Turn Signals Blinkers & H4 Bulb" ? Says it won't fit 2008 Street Glides...or will it with a little bit of modification like you did?
repsol69
5,072
Pt. St. Lucie, FL.
Heres the one i installed its not the Halo one...it fits but you have to trim it a little
repsol69
5,072
Pt. St. Lucie, FL.
Few pics for a member that wanted to know what i had to trim off light...here ya go T-bonewelldone
Looks great! The pic on the box has white lights & amber lights...Do you order one or the other or does each light have that option? Thanks Rep
