input needed 7 neck /9 tree or 9 neck/7 tree
tboner
1,558
ok, im in the process of ordering my parts for a 26" wheel and a question came up about the neck configuration.
I want to keep the wheel tucked in and the space in the neck to a minimum.
I wanted to order a 7 degree neck with 9 degree trees and the suggestion came up from HHI that I should do the opposite, a 9 degree neck and 7 degree trees.
my question is what would be the difference......they HHI strongly suggest doing a 9 neck and 7 tree.
I didn't want to do anything until I had achance to get CB input...
I want to still run a crash bar too.....any input would be great
I agree with HHI, do the 9* neck in case you want to switch to a 9/9 combo later.
tboner
1,558
I dont think its a matter of having the option of changing, they hhi want me to sign a release if I go 7/9tree. Its pretty obviouse they are worried about wobble.
BUT....I have read alot of people doing same even Paul at NCB said a 7/9 would be fine and not look too stretched. Actually when you use a yaffe or pickard nck kit your basically setting the stretch so I dont understand the difference....
Stretch and neck angle are two different things.
tboner
1,558
its the large gap between the tank and dash im trying to reduce and still go 26"
tboner
1,558
I just got ff the phone with HHI and wanted to share....now this guy talked fast so I hope I captured it right.
he said stock trail for a 08 streetglide is 6.2
if I go with a 7 neck and 9 tree with 1" adapters the trail would be 7.3
if I go 9/9 with 2" adapters the trail would be 7.7
he advised not to go 9 neck and 7 trees. I didn't cature why as I was trying to write down the notes.....
So basically 7/9 would be closer to stock.
Appling Bagger
1,472
looks like your struggling with the same thing I was. I just went ahead and went 9/9 since it's proven-you could alway go 30-and I'm doing my own neck so stretch wont be an issue. Mine stretch will be very short.
tboner
1,558
Paul at Native said you can do a 7/7 on a 26" too...he posted a silver bike with that combo
HawgSwag26
836
Tampa, FL
I went with HHI 7/9 because I didnt want too much of a gap from the frame to the wheel. Np198 did his Road glide 7/9 and it came out with a great stance
tboner
1,558
Yea I spent a good amount of time reading member builds and I'm digging the 7/9, Like the trail numbers and not a big fan of the long gap.
Decision made and order placed....now the wainting game for them to arrive.
