DonJulio
- 121
- Connecticut
I'm using a 1" lowering kit with my trees for my 23 install. I got a burly spring kit with long and short spring they call the short spring a helper spring. I also have fork tube adapters MB-1046's which I believe extend the forks 1" they replace the oem lower fork stops. With the trees I recieved what they call a top out spacer which consists of a 1" piece of PVC and 2 washers that get installed on top of the springs.
I'm trying to determine if I use the both springs and the PVC pipe and washers. It doesn't seem possible to install the cap with all that stuff.
