Josh1
- 437
- Palm Shores FL.HX
So I put a 23" wheel on my 2011 fhlx used Pickard trees, put in the lowering springs and stops that were provided in forks, with new heavy weight fork oil. Put on brand new pads have correct pressure and balanced new wheel.
The annoying issue is when I pull in the front brake I get a pulse its like a in & out motion on the front brake lever.
Now I know the first thing folks will say is its your rotors there warped! Well its not the vendor who I got the wheel from gave me two brand new floating rotors. Its still there, so I packaged up the wheel and sent it back to the vendor, he went thru the whole wheel, hubs are perfect, bearings are perfect, wheel is perfect, this vendor has went above and beyond for me.
I am just stumped I can't wrap my head around what is causing this, its not enough to be fatal, its just super annoying!
So what should I do guys, has anyone ever had this, heard of this. I have been fighting with this for months and I'm about ready to go crazy…
Also to help you guys out New wheel & Rotors have about 300 miles on the set-up, new pads were purchased from harley.
Thanks & Merry Christmas
