Foam work on fender and bags
sscglide
299
uploadfromtaptalk1432311433353.jpguploadfromtaptalk1432311484027.jpguploadfromtaptalk1432311503281.jpg foam work is done just gotta true up some edges and set my gaps whats the process you guys are using when doin the glasswork over the foam
DSmoke
816
That looks great!
Make sure your gaps are a little wider than you want. I ( and OSG, Gumptattoo) all used 1.5 chopped mat and thin epoxy resin from U.S. Composites. That is where we got the foam to as it is all compatible. I would suggest cutting your pieces ahead of time, do your corners first and have at least an inch or more wrap around. It is difficult to get the mat to wet out and lay nice around a corner. Then do your flats. I wish I would have known that as I found out the hard way. I did 3 layers of mat. I got all this from the DIY threads from Tcenzi and DMC. Oh, and get yourself a fiberglass roller, helps get the air out.
Warped
972
Is it spray can or two part mix or what?
Got a part # or pic of it...A Link lol
Gumptattoo
267
I agree exactly with what Dsmoke said. Your doing great and I am glad to see more guys are starting to do this. I like the way you did yours for sure. I didn't a flip at the end and the out side of my bags curve in instead of having a corner at the back. What a pain in the ass that turned out to be with glass. Get some dura glass or tiger hair to help any trouble spots before body work. I found that the glass was very strong after three layers and mine only have two layers on the inside and is just as strong because it has the foam as a backer. Are you gonna do the three layers of glass on the fender then carve the foam off of the inside? How thick is the foam on the fender?
sscglide
299
Ya im going to do 3 layers the foam on the fender is only about 1.5 to 2 inches thick and the bottom where theres no fender to back it ive already cut it down to about the same
DSmoke
816
You'll be hating life soon when you get to the body work, but it will be worth it. Your parts are looking good.
