Crazy idea for air ride psi indicator...
1,272
Colorado
That's a damn good idea. If you mounted an inline valve stem, you could carry a couple different LED caps calibrated for 1 rider, 2 riders, or pulling into the lot on bike night...
1,449
Southern MD
actually, sounds like light would go out when attained... but this is self setting... meaning you put the TPMS on the tire when it's inflated to desired pressure, then it will sense low pressure side when it reaches a setting below "normal". I think it resets itself when taken off and reinstalled. So you would need only one, but a gauge would still be needed to know how much air is in the system.
T
Thomason Performance
Could you use an offline gauge to set the pressure, then install the cap to set it to that pressure? Wouldn't it light up every time you aired down to slam it though? Could act as a fake security light then I guess...
ddavis
365
AR
Great idea, but I have heard those work about half the time. About as reliable as the oil temp dipstick.
Gary H.
1,093
St. Louis, MO.
Yea, I haven't heard anything good about the reliability of these. I know quite a few that don't work correctly. If they have fixed them, you could always run and inline valve step through the fairing and just screw this onto it in an obscure yet visible location.
