Converting back to Two Seater
ramnj
1,037
NJ
I would like to convert my bike back to a two seater, but not sure how to go about it. Went to the Harley dealer and the part that goes in the fender does not look like it will work on a Sinister fiberglass fender.
Any recommendations???
Gary H.
1,093
St. Louis, MO.
I had a fiberglass fender on my King. The guy I bought it from, just had a 1/4-20 nut under the fender, but it worked. I took a dremel and formed a slot for the Harley piece that goes through the fender and is held in by an E-clip. The fender was too thick for the E clip to work, so I just epoxied it in place. Its held there for years and is still there. I'll probably do the same when I put the new fender and bags on this one.
808Bagger
3,143
Oahu, Hawaii
Hey Raf! This is my plan. I have a passenger pad that I use and I was planning to reshape the pad and make a point in the rear and make it contour to the back side of my solo seat. Beef up the pad with more cushion and reDo the whole seat similar to my neighbors style...ImageUploadedByTapatalk1341082330.824289.jpg just a suggestion but part of my plan. I still, will have the option to go solo...
ramnj
1,037
NJ
I was thinking of doing the same thing but wondered how it would look/work.
ramnj
1,037
NJ
Hey Raf! This is my plan. I have a passenger pad that I use and I was planning to reshape the pad and make a point in the rear and make it contour to the back side of my solo seat. Beef up the pad with more cushion and reDo the whole seat similar to my neighbors style..just a suggestion but part of my plan. I still, will have the option to go solo...
Thanx Noel. I would prefer to go the pad way too. How do you attach it to the fender? Suction cups?
TraceCave Customs
1,758
Huntsville AL
I just laid my two up seat on there and marked where the bolt would go then drilled and tapped the hole there. Sinister had a steel plate molded in in that area so really it was a cleaner look than the floating nut would have been.
ramnj
1,037
NJ
Is the metal plate on all the Sinister fiberglass fenders?
ramnj
1,037
NJ
Gracias Suave. Now to decide which way to go. Gonna look first at the pad option.
ramnj
1,037
NJ
Going to the garage to see if it has one. Hopefully a magnet will detect the plate.
C&C also makes a pad but only works on metal fenders.
ramnj
1,037
NJ
Found the metal plate. Now just have to decide which way I'm going to go.
Would really prefer to go with the pad. Now to look for one that will work on fiberglass. Otherwise, I might have to drill.
Bagged64
1,774
Apple Valley, Ca.
If you get the pad with suction cups, just remember to take it off if nobodys going to sit on it. My buddy can tell you it's not cool to pick your wife up from work and she has to sit directly on the fender because it flew off. Haha!
