clutch cable and abs line question!
Bare Knuckle Baggers
524
Dirty south
hey i just ordered a set of carlini evil apes for my 2010 road glide with abs.. does anyone know how long the clutch cable needs to be? Also since my bike has abs and im keeping the lines black i was wanting to just replace the line from the front master cyc to the abs module and leave my lines to the calipers stock, does anyone have any info on how long that line needs to be and where can i buy both lines at? thanks for your help.
What size bars and is the frame raked?
I use Magnum Shielding for lines and cables...
The King is getting a full internal setup.
I would guess +8" on the clutch and upper brake line.
That may be a tad long, but that's easier to deal with than too short.
The only sure way to know is mount the bars and measure using your stock cables.
Baddd bagger
Moderator and Buddy.
5,046
North jersey
I did 14 inch on my sg and a plus 8 wasn't even close so I went with a plus 10 don't know if that helps u at all , I have a plus 10 kit on my bench for sale if u change ur mind and want to go with braided stainless
Ride it like you stole it!
1,272
Colorado
While we are on the subject... is there a kit out there to re-do dual front ABS brake lines so the "T" can be relocated somewhere other than the bottom side of the trees? (2011 SG) Thx!
I did mine using lines with -3 fittings and a -3 Tee.
Most likely proving once again that there is such a thing as a stupid question... Is "- 3" the same as "AN-3"?
Yes, AN -3 just means mil spen "Army Navy"
JIC fittings and AN fittings are pretty much interchangeable.
