Changing fork oil.
Coach
202
Dallas TX
I have my lower legs off the bike. Im gonna install my lowering kit in them and had a question about the fork oil. Can I just turn the leg upside down and drain out the old fluid? the simply refill it with the amount removed?
Baddd bagger
Moderator and Buddy.
5,046
North jersey
I just took the bolt out of the bottom of the fork and then gently push up on the fork and it will push the oil right out u might have to do this 2 times
Ride it like you stole it!
Coach
202
Dallas TX
Okay so installed all the new springs and when I got to the long spring it stuck out past the upper portion of the leg. About 1/2 an inch. So I couldn't use the spacer. Anyone encounter this. It's the same on both legs.
That's ok, that's your preload. You may need to cut the spacer down to adjust your preload. You'll need to compress it by hand to get the cap back on. Could be a pain in the ass.
Coach
202
Dallas TX
I called progressive so between your input them and common sense I'm in the good. Thanks again foreveryone's input. Now back to work.
