can i swap the rotors, calipers, brake lines, and master cyl from a 2008 street glide with abs to my 2007 street glide and swap my setup over to the 2008?
I dont want abs on my 07 and dont care that the ABS wont work on the 2008
U can swap the calipers, rotors, and master off the 08 to the 07. But the brake lines will not work because u have abs. the brake caliper line runs to abs pump in right side cover than back to master. So u would have to get a front brake line for a non abs 08 and up bike. The o7 brakes will not work correctly with the abs on the 08. U could just plug the the 2 lines fitting on the Pump and bypass the abs. Then install the calipers, master, and line from 07 to 08.
U could leave lines on 07 but the banjo bolts for brembo is metric and is a 10mm. As the older brakes are 3/8 banjo.. Dont think the abs on 08 will work right with the 07 down master
