BDL Open Belt Help.
jerzee_tek
867
Elizabeth, NJ
Wassup guys,
Hoping you guys could be a little more help. Installing and open belt on a 13 road glide.
1. Is converting the bike to hydraulic clutch going to be a problem?
2. For the front pulley... They sent 2 big washers and a spacer which I assume is for behind the front pulley and a smaller spacer and washer and a bolt which I assume is for the front of the pulley to tighten it up? Do you guys know if both washer are to be used and in what order?
Cant get in touch with BDL nor can I get a phone call back.
jerzee_tek
867
Elizabeth, NJ
Well, got in touch with BDL finally.
1. Hydro clutch conversion will depend on setup but they do have parts to update if needed. I think I'll be ok with my setup.
2. The spacer and washer are to be used as shims as needed to get the pulley aligned.
Sent from my SM-G955U using Tapatalk
