Avon Cobra tires
gwphelpss10
681
Somerset, Kentucky
I was wondering if anyone had problems with the Avon tires leaking down? I have checked the seal around the rim. Checked the valve stem and core and can't find any leaks.
T
Thomason Performance
pull your tire. double clean your tire bead and your wheel bead - removing any chunks - a good wire brush is the best on the rim. Re-install and re-seat the tire then see if you have any issues after that. Avon's don't leak, and if they do you have a hole or the tire is not properly seating on the bead.
gwphelpss10
681
Somerset, Kentucky
I'll just break it down. I'm sure it's not anything wrong with the tire. It leaks about 2 psi a day. Not going to worry about it this weekend. We have a ride scheduled to Cherokee NC and the Dragon this weekend.
