Another Street Bob to Dyna Bagger conversion
streetboy80
14
Another Street Bob to Dyna Bagger conversion.
Well, I have started first a thread in a another category but I think this might be the correct on.
Here some facts of my Bike:
-2007 Dyna Street Bob
-23†front 18†rear
-Arnott air-ride
-front air-ride (in process, probably in about two weeks I’ll update this)
-4†Tommy&Sons Saddlebags
-Rear fender ala Bad-Dad style
-Wide Glide Triple tree
-Santee mid Ape-hanger
-New exhaust system V&H big radius 2-2 (I’ll update the pics in a few days)
-self made double seat
I was struggling a lot with the bracket system for the saddlebags but I think finally I found a solution. Main problem that I had was that the bike wasn’t level to the ground so I had to “simulate†the Front-Air ride system and I slided the fork tubes further into the triple trees. The front air system will be pumped approx. 2.5â€-3†So I would have enough clearance between the front fender and the lower triple tree.
Once the bike was level I have started to mount first of all the fender in order to see the shape and the angle of the tail of the fender. In combination to that I figured out the vertical position of the saddlebags watching from the front and from the side view (that was horrible!). I took me a few hours between deciding the minimum height. I decided to mount the bags with a little bit of angle (side view) so it always keeps the bike a bit longer and gives it a lil bit of the “lowrider-lookâ€
Next steps will be mounting the Road Glide fairing with the compressor for the front system in the inside of the fairing and see what happens ;-) the winter just began and I’ll do the work “Poquito a Poco†that’s how we say it here in Spain :-D I hope you’ll like it and I’m always happy to receive your feedback and probably some kick’n ideas from you guys ;-)
Cheers & saludos, Tommy
http://tinypic.com/view.php?pic=20hq3pd&s=5
http://tinypic.com/view.php?pic=2ps164l&s=5
http://tinypic.com/view.php?pic=2gsiq1i&s=5
http://tinypic.com/view.php?pic=14uf7ty&s=5
http://tinypic.com/view.php?pic=161m9eb&s=5
http://tinypic.com/view.php?pic=m8ctw8&s=5
Sticky4
175
Were the rear bags and fender bolt on or they needed to be custom mounted and cut out for the shock?
Nice work so far....
streetboy80
14
The bags+Fender have to be modified. I had to cut off a part of the inner side of the bags but it's a 5 min job. You just have to make sure which height of the bags you want. I did it with the air shocks inflated to make sure that the whole line of the bike is ok.
Later I put the fender on to see if it matches perfectly with the shape and the distance between the bags is correct.
I'll post soon more pics.
