air ride leaking
metalmaniac
1,158
DENVER,NC
Cant figure it out. Rear goes down in about 30 minute. sprayed with soapy water.... no bubbles. I replaced the lines from the shocks all the way to the block. sprayed the shock fittings... nothing. I am running brand new air F/X shocks. I even sprayed the accuair block. I know I am missing something somewhere
DSmoke
816
Carlisle, PA
Can you remove the air line from one shock and cap it, then do the other to make sure it's not one of the shocks?
Diesel
288
I had a problem similar to yours and it was my check valve at the compressor. You may wanna check that.
7,353
not sure what compressor you are running jay, but both 280's i had, the check valve failed - but it would cause the whole bike to drop with the accuair block.
