ABS Single front Brake line. where to buy. how to bleed?
miarzr900
83
converting to a Single front Brake line on my 2013 road king.
where is everyone buying their lines?
is the bleeding process the same as any other system? is abs different? pump, pump, pump, hold, release air, repeat?
once i take the old line off the block do i need to bleed the back??
thanks fellas
venomized
895
Georgia
As long as youre only replacing the line BEFORE the block you can just let gravity do the work from the master fown to the block. If you try to bleed any further back, youll need to hook it up to the machine at the stealer.
I bought my Russel line and fittings on ebay.
miarzr900
83
What do you mean by "before the block"?
I think all i need is the line from the block to the front caliper correct? Is that what you meant?
venomized
895
Georgia
Frok the master on the handlebars to the block. If your replacing from the block to the front your going to have to take it to the stealer to have it hooked up and bled
BlackGlide
353
They bleed same as anything else. I replaced both lines last year and never had an issue. I attached the cable at the master cyliner and let fluid gravity to the block before i attached it at the block, replaced the lower cable with the same method and then bleed as normal.
