ABS brake sensor question
DonJulio
121
Connecticut
I have American Suspension fork lowers with ABS brakes, does the sensor index pin just kinda hang out behind the leg with no real place to go? Basically slide the axle in and have the sensor rotated to the back so the wire runs up behind the caliper?
Yep that how it works. Just rotate it upwards, before you tighten the axle nuts, so that you'll have enough play to get the caliper back on.
DonJulio
121
Connecticut
Thanks. Seemed kind of cheesy at first, but It's all coming together slowly. Just Swiss cheesed the inner for more speakers.
