2010 SG fairing to 2019 Roadglide fairing
mstng5point0
60
Southern NH
It is possible. Infocus Mobile Audio has done it. Look them up on facebook or Instagram. Just finished a lay frame 26 with a 15 RG fairing.
jahnke83
3
Get a Harley parts catalog. I got a 09 street glide cheap enough and switched it over to a 16 road glide. With working radio.
metalmaniac
1,158
DENVER,NC
It is very doable. I did it. Easy. Just buy the entire inner and outer fairing. The new glove boxes. Also need the speaker pods and vents. A new radio support and headlight assembly.
jahnke83
3
Great job. I guess I have to change the wiring harness and all for the radio and all to work or is that the same?
Yea, you can do aftermarket radio and maybe have $2000 into it if you find some good deals, I use oem parts. Doing Harley radio will cost you. Can bus system. 2015-2016 wire harness, ecm, bcm, ignition switch, gauges, hand controles, battery trey, handle bar riser clamp. (Or mill yours down new ones are shorter)
jahnke83
3
Also search part numbers it's amazing that you can buy new parts cheaper then ebay. I use surdyke, and new Castle alot. I always buy the brackets new don't want any from a bike layed down. Fairings, radio, and headlight are the big expenses. Search ebay, market place and craigslist, and be patient.
