2001 classic to roadglide 26" build
75bbuzz
127
Pickup a 2001 classic with a little road rash. Decided build a 26" RG. Tore the hole thing down and started some mock up.
Sent from my SM-G930R4 using Tapatalk
75bbuzz
127
Chopped the neck and put a misfit short neck on it and re-powder coated the frame.
75bbuzz
127
Started getting the trans back together. Going to go with a hydraulic clutch setup on it. Running the wires threw the frame sucked though 20161213_150720.jpg20161213_150945.jpg20161217_155044.jpg
75bbuzz
127
Thanks guys.
Got the lower end put back in and tightened up. Hooping motor up from 88" to 98" and stage 2 heads and upgrading oil pump cams and cam plate. 20160925_104121.jpg20170101_124705.jpg
75bbuzz
127
Got the rear fender on. The LED's are custom dynamic bag filler lights. I cut the edges off and fitted them in the fender
75bbuzz
127
Getting the front end put together. Put the caliper on its a street bike type, but I do have the caliper mounts that I can change out to allow for the stock setup also if I want. Not looking to bad. I stretched the gas tank and I set it on to see how it looked.
75bbuzz
127
Still slow progress but it's coming along. Mocked the fender and handlbars up. The gas tank looking better now. Picked up parts from the powder coater also.
75bbuzz
127
Ya it is. It sucked I found out the hard way. Had to read glass it all over the place to make it work.
75bbuzz
127
Thanks! Going slower than I want tho
DanHappy
509
Take your time and enjoy it. You will look back at the time and wish it lasted longer.
Sent from my SM-N910V using Tapatalk
