I am setting mine up with stock forks with travel limiters.
You can get the limiters from Native Custom Baggers.
Bill are these on there site I didn't see them there.
Lowered or limited... Either way you are reducing total travel, doesn't make a difference.
I used American Suspension Legs. Arlen Ness makes a similar smooth leg. They also offer a new dual 4 piston caliper setup that is on a single rotor. Pretty bad ass except it will not allow for a 13" rotor, stock size only.
I was of the understanding that if these were used, the suspension travel stays same as factory and allows the use of stock length fork tubes? True or False?View attachment 3596
Before I waste $ is this what I should be replacing on my hhi kit with something longer or what is it exactly pictures if you got them.
