10" sub woofer saddlebags
pickardbaggerparts
761
Richardson, TX
Heavy Hitter 10" Sub Woofer Saddlebag Set!
Patent Pending # 29/399070
These are by far the hardest hitting baddest bagger audio product on the market. If you want your bagger to have that Heavy Hittin' Sound that comes from these competition car audio rides this is the product for you.
Make your buddies with the loaded up 6"x9" speakers look like fools.
Bags include either (1) one 10" sub or (2) 10" sub woofers. Use your OEM lids and hardware.
Still use your bags load em up with all your goods you only loose about 10% of your stock bag space.
This set of contoured saddlebags dress up the sides of your ride. No more boring bags! A one piece 4†extended over factory length saddlebag set that can be utilized with existing HD lids, hardware and mounting. Our bags are fully extended inside as well as out for all that extra storage needed on your riding adventures. Saddlebags structure is made of vinyl ester reinforced fiberglass. Vinyl ester laid fiberglass is stronger and more pliable with increased corrosion resistance and ability to withstand water absorption and different temperature draws. Made of fiberglass…
These Bags are molded with the sub-woofer pocket built into the bags these are not built with a speaker ring glued into a bag. The bag is also thicker to accommodate the the pounding from the 10" sub-woofer.
Sub-woofer 10" slim mount 2 11/16"
Power Rating RMS= 200W
Power Rating Max+ 400W
4OHMS
• Fitment HD Touring and Softail 1997-2012 models.
• One-piece fully extended Saddlebags are 4 inches longer, inside and out, compared to factory bags with extra deep inside storage
• Utilize your HD OEM lids and hardware
• Bags are lined with our signature lining
• Made of vinyl ester reinforced fiberglass-stronger and more pliable than the rest
• High End Gelcoat finish and Primed paint ready
• Made of Fiberglass, Not ABS! Fiberglass can be easily modified or repaired, ABS cannot
Dual Exhaust, Single Exhaust, No Exhaust Cut outs
I think these bags would have totally changed my build plans had I seen them six months ago.
