09 sg wheel
Buggy
1,279
Pittsburgh Pa
So my buddy has a 01flh standard,he went to put on an 09 wheel got the installation kit for his model and th bearing on the left sticks out 1/8 inch after it is pressed i. Any input fellas?
T
Thomason Performance
The 1" bearing required for the older axle is wider than the bearing journal on the '09 wheel. You can run it with the bearing sticking out a little - just looks weird. Plus you'll need new axle spacers that are shorter. I don't think there is a 1" bearing that skinny that will fit, but you could try some bearing shops around your area to see if they have a bearing with a 1" ID, 52mm OD, and a width of 15mm...
